IN mast main sail furling mechanizm
msade
Feb 3, 2011
21
beneteau oceanis 440 haifa
Dear sailors
I own a beneteau oc 440 model 1993 sailing yacht.
The mast is ZSPARS with in mast furling main-sail .
I want to overall the bearings of the unit without taking it out,
as the unit can be disconnected from the mast only by stepping down the mast-a procedure I am trying to avoid.
Will appreciate any advice regarding the possible use or experience using
the openings in the mast and special tools needed
Thank you
Oct 27, 2010
119
E-22 e-22 Stratford
Attached is the Z-spar furler tuneup guide. They (in north america) have a very affordable servicing deal on the system.
You can contact them at: 800-928-0728 and ask for Rick.
PDF attached.
Bob Pattison
Neil Pryde Sails Int
968
Beneteau 352 Hull #276 Ontario
I don't think that's what he's looking for. I looked at some pics of the
440 model and the mast furler is not like most that I have seen. I don't see anyway to access the furler mechanism without dropping the mast. It seems like a crazy setup. If it's stiff turning you might get away with a low pressure wash of the bearings with fresh water. You shouldn't use any lubricating spray as it will attract dirt.
Good luck
msade
Feb 3, 2011
21
thank you for the replies
Joker460 is correct - The unit cannot be taken out without stepping down the mast - a procedure I am trying to avoid.
I am thinking of building a special tool to open the bearings of the furling unit
through the opening in the mast.
enclosed are two pics of the lower mast section
