I mast furling TIP
I got my hunter 430 new in 1997. Always have had problems with the in mast furling. It's been a real struggle and all of the comments on this forum have been helpful. This time when I went down to the Bahamas and put my boat in the water, I had problems again. Struggle, pull a bit out, furl back in, back out, after about 45 minutes finally got the sail out. This time I tried something totally different. I'm surprised I didn't think of it before. The problem with the sail not coming out is that the Mast is not very roomy and there is friction with the sail against the internal aspect of the mast. So, I went up the mast in the boatswains chair with a can of silicone spray. I simply sprayed both sides of the mast internally, I suppose some got on the sail but I don't think that will hurt the Dacron sail. It was an easy job, I did about two thirds to three quarters up the mast . Took me about 45 minutes. Sail goes in and out easily now. Don't know how long this will last but I may end up doing this every couple of months. Wish I had thought of this one earlier. Would have saved me a lot of grief. I should add one other comment. These sails do not come out by simply yanking them out with the out haul. They work best when you have wind to pull it out. So I always have my wife point the boat about 10 or 15° into the wind and the wind will simply pull the sale right out for me.
Hope these comments will be helpful.
