performance secret
Since in-mast-furling mains are necessarily loose-footed, trimming the outhall is far more important than on conventional sails, where people tend to set the tension for the day and then leave it there. Depending on the cut of the main, the center of the foot should be about 4-6 inches away from the boom when going to weather (unless you're overpowered and flattening on purpose). What this means is that every time the wind changes, and every time the apparent wind angle changes, you adjust the outhall in rseponse in order to keep the shape where you want it. On the other hand, a broad reach calls for much more belly in the sail, where the foot is eased at least a foot away from the boom in order to power things up. On an average day I'm adjusting my outhall every 15 minutes or so, and even after six years of sailing with a furling main I'm still amazed at what a difference small outhall adjustments make. Think of it this way: if the foot of your jib has a different shape than the foot of your main, one of those sails is trimmed wrong.
