My question is related to the use of my outhaul and Cunningham in light airs. My tendency is to like the look of a nice smooth flat sail and to likely overuse these controls when I could use a little more power in the sail. Should I be using the two controls to just remove wrinkles and leave the maximum depth in the sail possible in light winds or since this seems to take some depth out should I be leaving them alone? Though I am working on it, my main halyard will not take the main all the way up for some reason so I feel I need to use the Cunningham to pull the tack down some.
After the telltales, I next look to remove wrinkles in my jib as a way to get good trim on the foresail so it is tempting to start hauling on the main too!
Thoughts?
Thoughts?
