Capn: Yes, amps per hour is what you want to be cognizant of. LED's was a good move. Those gudgeon screw holes need to be cleaned out enough so you can get some resin and matt chop pushed down in those worn hole areas. Clean them out until you find solid glass again and then fill. Sand off and drill carefully for new screws or if you can you might want to stainless bolt/big washer it. Thats probably your leak also. Hell, if you can get to it and bolt/seal the rudder hardware through the hull you may not even need to do any glass repair back there! The 5 hp motor was a great move! Chief, (cash95916@yahoo.com)
