My stern pulpit is loose, and not mounted in a couple spots. Was hoping to put a bracket (something to hold the rail and mount it to the surface) around the bottom of each rail.
There is a cable running up through the stern pulpit. Maybe this needs to be taken out or replaced? Otherwise I'd need something that could be deck mounted in two parts, as I wouldn't be able to slide it under the rail.
Hoping to be able to mount davits to the back.
Thanks!
Aaron
Thanks!
Aaron
