Removed the original Johnson (not Yanmar!) impeller from my 3JH4E Yanmar engine. However lubrification was not included with the new Johnson impeller, so my question is what do I use as lube.
Also, Yanmar states in its Operation Manual that impellers should be replaced every 1000 hrs. But on the forum I read that it is advisable to do this every year. That's quite a difference, so what's wisdom...?
(Difference between knowledge and wisdom:
knowledge is that you know that a tomato is a fruit, wisdom is that you don't put tomatoes in in a fruitsalad!)
Also, is it advisable to remove the impellor during winterstorage or during long times not using the boat and thereby taking the strain of the otherwise bended (or is it bent) rubber....? A bit like jacking up your car during longtime storage.
Peter A. Braam
o/b sv l'Entropist
Marina Muiderzand, the Netherlands
Peter A. Braam
o/b sv l'Entropist
