A warning to those of you who might go to the local chandlery for a new impeller. We replaced the impeller on a Yanmar 2GM20F YEU in April 2006. We put very few hours on the engine during the six months of this past summer. The engine ran normal right up thru haulout on the day after Thanksgiving. But when we disconnected the sea water intake hose and tried to pump a gallon of antifreeze thru the salt water system, Nada, zero!! Nothing pumped. Opened up the pump casing and discovered that the engine had eaten two whole impeller blades!!! All we can figure out is that the impeller installed in April must have been on the shelves of the local marine dealer for a long time and was probably brittle. The good news was that it must have broken just as we shut down the engine for haul out, because there was no overheating while it was running. How seldom does one get a break like that?The lesson here is that impellers apparently do have a shelf life. Torresen Marine's repair guy says that a good way to test for viability, is to bend over one or more impeller blades, and if they are inflexible, crack, or have trouble returning to normal configuration, then the impeller is old and should not be used. He said that Torressen pays attention to shelf life of their stockage.By the way: the 2GM20F engine model number is insufficient data for ordering some parts on this Yanmar (and perhaps size engines). Turns out that when the Yanmar serial starts with an "E", then the engine is a European Yanmar and a number of parts can be different from the Japanese models for instance impeller, pump "O" ring (vs paper gasket), and two belts. The European Yanmar is described by the model number 2GM20F YEU, even though Yanmar doesn't put that "YEU" on their engine label. It is not intuitively obvious in Torresen's web site that you have to be aware of this fact. Caveat emptor!!!!!!!!
