raw water impeller pump on yanmar 4jhe 1989
Having trouble fitting new impeller..........
any ideas solutions ?
what exactly do you mean..... is it very tight going in?? Did you snap picture before you removed the old one? I just changed mine for the first time on my 4jh4e (2005) and it was tight.... but doable. I always snap a picture (or many) before I remove anything just as a reference point. I also grease the shaft to help go in and for it to come out next time I change.
Greg
Or use a hose clamp, it doesn’t take much to get it started. Also lube the shaft that spins the impeller.Try folding the blades some with cable tie. It may help easier inserting. I understand you don't need to bend blades in right direction as it'll sort itself out once it spin. Your call.
Ken Y
