Impeller
2
Oday 28 kentucky dam marina
After Replacing The Sherwood Impeller For My Universal 5411 Motor, No Water Is Moving Thru The Motor. Water Was Moving When I Winterized But Now None. The Impelled Only Had Two Out Of 12 Vanes Left And I Picked Out Several Pieces But Not Sure I Removed Them All. The Raw Water Inlet Is Not Obstructed. This Is My First Attempt At Doing The Job Myself.
7,743
Alden 50 Sarasota, Florida
It doesn't take much to block the flow on a 5411. With no heat exchanger, the debris could be anywhere but check the simple stuff first like the exhaust elbow.
