impeller type
sdstef
Jan 31, 2013
140
Hunter 28 Branched Oak Lake
Anybody know if the Yanmar 2GM20F has a "keyed" impeller or straight bore? Boat is over an hour away, and wrapped up for winter. Boat is a 1991 Hunter 28.
Thanks
Reg M
May 21, 2016
131
Hunter 31 Montague
See my recent post regarding 2gmf impellers. I have two impellers which will not fit my pump but may fit yours. You can check the internal parts carefully against the Yanmar parts list and diagrams to determine which pump you have. In my case I have the pump shown in the first diagram and the impellers are a bit larger that the others. Reg
MitchM
Jan 20, 2005
1,031
left and impeller looks like it's missing part of the tip at 5 o clock. hope it's not stuck in your heat exchanger...? is th engine running hotter than usual ?
