impeller swap out
J Cianflone
I need to find out how to swap out the impeller on a Rc8.Any special tricks? Should I coat the impeller with anything?
Jack Laird
No tricks
The only problem with the impeller change is that the pump has to be pulled as the impeller is on the back. About a twenty minute job the second time. You may need new bolts for the pump impeller plate the first time you change the impeller.
