Those are all good ideas. Now here's the easy way
to do the same thing. Symptom; missing impeller blade. Remove the small hose to the heat exchanger. Blow, blow, blow. (Good one Franklin!
) If nothing, remove the front cover of the heat exchanger. It should be there. If not, don't worry about it. Put it back together and go sailing. But take that cover off. One impeller blade will get trapped here and significantly reduce flow. Check out the cover O-ring. See how it compartmentalizes the flow so as to switch it back and forth three times? That's so as to gain maximum heat removal with available seawater. It's important to check here.Now if you also find significant scale in the tubes, DO NOT FRET!
) sorry, too much fun) Go to your local Home Depot (or any hardware store) and pick up one of those really long drill bits used by electricians for making pilot holes. You want a 1/4 inch bit. Chuck it up to your drill. Start it in each heat exchanger hole by turning the chuck by hand until it's lined up in the tube. Then apply power. It's best to have a variable speed drill. Then just push it in to the rear of the exchanger. The bit stops at the back cover. Push no more. Do the next tube and so on. No need to blow out the crud. It'll flush out when you reassemble and start the engine. That's it. Put the cover back on. The O-ring is probably reusable. It's really a rubber gasket. It took a lot of typing to describe a really simple job. Once you see how easy it is, It'll be on your list of regular tasks.P.S. ROSS! I think there's a rule against arousing Posts!
