Impeller pliers with bent tips?
Jun 14, 2011
76
Hunter 37.5 Legend 1993 TX
I was helping a friend on his Hunter 466, which has a 4JH3E-TE engine. The raw water pump faces backwards, which makes it hard to pull out the impeller (without removing the whole pump). I used a 90 degree needle nose pliers to pull out the impeller. (Let's skip all the discussion on how hard it is to access -- that's a given.)
In some publication, I remember seeing a 90 degree needle nose pliers, but with an extra inward bend at the tips. The small bend at the tips bites into the impeller body, thus giving you extra grip.
Does anyone know where I can purchase that tool? If you used one, does it make it easier?
Feb 8, 2014
1,300
Columbia 36 Muskegon
When I had a Yanmar I just pulled out the pump reach time. It wasn't that hard to do, easier than wrestling with the backwards impeller.
Jun 14, 2011
76
I have worked on many Yanmars. On this particular model of boat, the lower part of the engine is sub-floor, making removal more difficult.
All I want for now is to find the tool as described.
Feb 8, 2014
1,300
That would make it harder. If you can't find anything pre made, you could take pair of extra long needle nose piers, heat them up with a torch and bend them any way you want. A 180 deg turn would the tips inside with the handle still facing you.
Mar 20, 2012
3,983
in your browser, type in, bay shore marine impeller puller ,and you will see the tool you are asking about.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
The other option may be the bolt-in-a-bolt. If your impeller has threads on the outside edge there is a bolt you can buy that can be used.
129671-92110 YANMAR IMPELLER BOLT
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
just get a set of surgical clamps like in your tackle box ...or some of those cool roach clips like they used at woodstock :poke:
Gunni
Mar 16, 2010
5,937
Have the same engine in a B411. You have to be careful not to lever your steel tool against the pump body - you can damage the sealing surface, or burr the impeller volute. I use a Jabsco impeller puller. Makes quick work of the job.
