Impeller issues
j-fitz
Jun 13, 2011
3
catalina 30 York River
At the dock the boat starts fine with water comming out the exhaust, after a sail no water comming out the exhaust? Anyone have a this problem
Feb 7, 2010
55
Catalina Capri 22 MKII 1097 Grove, OK
What year is your C-30?
Is it a diesel?
What's your temp gauge read?
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Has this happened more than once? What year is the boat? Any other symptoms? How much heel during your sail?
Need more info!
j-fitz
Jun 13, 2011
3
1984 m-25 engine the degree of heel is a not a factor. engine temp climbs past 160 before I shut off engine.
jrowan
Mar 5, 2011
1,294
Sounds like you should replace your impeller as a precaution, as it is the most likely culprit due to its wear & tear. If your diesel is fresh water cooled I would verify good flow from the exhaust of the heat exchanger. It can be hard to verify water flow out of the exhaust port on the transom while underway, if you have wave action astern. The transom usually is covered with sea water. Where is your boat located on the York? My C-30 is at Crown Point Marina on the Perrin, off York River, near the mouth.
Oct 5, 2008
28
catalina 30mkii alameda ca
you might also consider checking the sea water thru hull for any blockage as well as the strainer at the shut off valve.
What thermostat do you installed. There are two available, 160 and 180.
No water means it's a blockage or an impeller. To check for blockage, I find it's easier to take the incoming hose off the raw water pump and blow back through it with a dinghy foot pump.
jrowan
Mar 5, 2011
1,294
Not a bad idea to clean a blocked line - haden't thought of using dingy pump, but blowing through the hose would likely also work & be quicker.
j-fitz
Jun 13, 2011
3
Have already changed the impeller, and I'm on C dock @ Crown Point on Celtic Ray
jrowan
Mar 5, 2011
1,294
Cheers, See ya sometime at Crown Point - I have the older 1980 5411 2 cyl. diesel so I can't really compare my engine to yours. I would guess as noted above either a blocked main water intake thru hull, or a blockage by corrosion in your heat exchanger. Take the hose off & verify as noted above. Good luck.
