				 citimarinestore.com
					citimarinestore.com
				Thanks. What does the bold vs. non-bold text mean? For example, fiberglass hull, brackish water: is Aluminum preferred?
If there is a question about the water, then use aluminum. In fresh water zinc will form a hard coating that prevents the zinc from doing what it is supposed to do.Thanks. What does the bold vs. non-bold text mean? For example, fiberglass hull, brackish water: is Aluminum preferred?
How do I determine if the river I'm in is salt or brackish?
Thanks,
jv
And how would they know how brackish the water is in the Westport River?Maybe better you don't rely on opinion. For the definitive answer just call PYI Inc. Monday AM.
Tel: 425-355-3669
Toll Free: 800-523-7558
Tell us what they say.
Charles
Good point.Just tell them where you are. They will likely have a reliable answer. After all they are MaxProp (exclusive sales and warranty repairs in North/South America and Asia these last 40+ years) so they will have received plenty of actual feedback over these many years whereas the rest of us do not have that kind of background. Anyway the call is free. What have you got to loose?
Charles
Thank you Charles, sound advice. I had read about same alloy for all zincs.No matter your eventual decision note two things: (1) Make sure the prop anode has a clean solid connection to the Max Prop - true of all anode fastenings. (2) If you have other underwater metals also protected with anodes (like the shaft, the shaft strut, the rudder and/or its post, etc.) make sure those are changed to the same anode alloy as the prop anode(s) else you might have anode protecting anode (depending on boat bonding and proximity.) That is not what you want.
Last, be sure what you buy meets Mil Spec - Matyr, Seashield - avoid any off-shore knock-off that does not carry this guarantee.
Oops I guess that is three things.
Charles
