I'm so confused! Zinc vs. Aluminum Anode for Maxprop?
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I found I had previously purchased an aluminum anode for my MaxProp, and I don't know why. A mistake? Did I do it on purpose? I don't know!!!
What should I do?
Thanks. What does the bold vs. non-bold text mean? For example, fiberglass hull, brackish water: is Aluminum preferred?
How do I determine if the river I'm in is salt or brackish?
Thanks,
jv
If there is a question about the water, then use aluminum. In fresh water zinc will form a hard coating that prevents the zinc from doing what it is supposed to do.
The salinity of the water in a river will depend on how tidal it is, how much fresh water is flowing downstream, and how well the water is mixing.
Two schools of thought....
  1. You dip a cup in the water, Taste it.
  2. You can be a Chem Major and use a test strip for Sodium Chloride.
Though if you are in a river you may find the salty taste is a whole bunch of other salts in the brew.
AquaChek Salt Test Strip Titrators for Pools - Salt Water Pool Test Strips for Sodium Chloride - Quick and Accurate Results - Professional Water Quality Testing Kit (10 Strips)
Available from who else.... Amazon
  • Helpful
Likes: JamesG161
jviss
Feb 5, 2004
7,090
Thanks guys.
John, I think it's probably pretty salty most of the time. I've been swimming in it, off the back of the boat, for over 20 years. But come to think of it, I've never made a comparison of flooding and ebbing tastes. :)
Reading up a bit, and learning about aluminum becoming passivated, I think I'll go with zinc.
Jan 30, 2012
1,150
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
Maybe better we don't rely on opinion. For the definitive answer just call PYI Inc. Monday AM.
Tel: 425-355-3669
Toll Free: 800-523-7558
Tell us what they say.
Charles
jviss
Feb 5, 2004
7,090
Maybe better you don't rely on opinion. For the definitive answer just call PYI Inc. Monday AM.
Tel: 425-355-3669
Charles
And how would they know how brackish the water is in the Westport River?
Jan 30, 2012
1,150
Just tell them where you are. They will likely have a reliable answer. After all they are MaxProp (exclusive sales and warranty repairs in North/South America and Asia these last 40+ years) so they will have received plenty of actual feedback over these many years whereas the rest of us do not have that kind of background. Anyway the call is free. What have you got to loose?
Charles
jviss
Feb 5, 2004
7,090
Charles
Good point.
jviss
Feb 5, 2004
7,090
The guy at boatzincs.com, where I buy my zincs, advised to use aluminum.
Jan 30, 2012
1,150
No matter your eventual decision note two things: (1) Make sure the prop anode has a clean solid connection to the Max Prop - true of all anode fastenings. (2) If you have other underwater metals also protected with anodes (like the shaft, the shaft strut, the rudder and/or its post, keel cooler, thrusters, etc.) make sure those are changed to the same anode alloy as the prop anode(s) else you might have anode protecting anode (depending on bonding and proximity.) That is not what you want.
Last, be sure what you buy meets Mil Spec - Matyr, Seashield - avoid any off-shore knock-off that does not carry this guarantee. Don't need to worry about motor/water heater internal anodes these can be any alloy.
Oops I guess that is three things.
Charles
Likes: jviss
jviss
Feb 5, 2004
7,090
No matter your eventual decision note two things: (1) Make sure the prop anode has a clean solid connection to the Max Prop - true of all anode fastenings. (2) If you have other underwater metals also protected with anodes (like the shaft, the shaft strut, the rudder and/or its post, etc.) make sure those are changed to the same anode alloy as the prop anode(s) else you might have anode protecting anode (depending on boat bonding and proximity.) That is not what you want.
Charles
Thank you Charles, sound advice. I had read about same alloy for all zincs.
My prop shaft is either stainless of monel - I can't tell. I usually put two zincs on the shaft and one on the maxprop, and when hauled for the winter the prop zinc is gone, along with all of one and most of the other shaft zinc.
I'm pretty sure I have an electrolytic corrosion/erosion problem. I bought a test anode from boatzincs, but haven't gone into it yet, as I'm in a river and you have to do this with zero current, etc. I think it's because I have multiple connections from the boat grounding system to the water. I was thinking it was because my bonding system is connected to the grounding system in more than one place. We'll see.
