I've been a long time reader, but this is my first post. I'm having trouble getting new alternators to work. Both my old alternators died last week, and I was able to get replacements (not exact replacements) in Prince Rupert, Canada. The new ones are "self exciting" Prestallite 8MR2069TA also known as 110-602. The salesman said just hook up the Positive, and the Tack to one of the AC lugs and we were good to go.
I did that, but got no output from the Alts. Thought maybe its because the other end of the Positive lead is a diode pack with 2 inputs and 3 outputs, start, house, and NoConnect, so we conntected the leads from the idiot lites to the positive terminal. I'm not sure now, perhaps it was late, or too many beers, but I thought it was working.
We departed Port Hardy heading for Ketchikan and after a few hours realized the start battery was well below 12 volts, and the House battery down to 12.4. We checked the alts and neither was producing any voltage.
Here in Ketchikan, I figured out that the alts are not case grounded, and learned to excite them by touching a hot lead to an AC post while the engine is running, and how to connect the idiot lights to via a relay to the AC post.
But they still do not self excite. If, after starting the engine, I touch a hot lead to an AC input, it outputs 14.3 volts, but otherwise nothing. I'm wondering if I need 12V on the Positive lead, like either routing around the diode pack, or connecting 12 Volts to the Pos terminal through a resister.
Jim
Jim
