Nope...no "one size fits all" kits available
Your toilet is a Brydon Boy, which was a Canadian version of the Par/Jabsco manual toilet, built under a licensing agreement...it's been obsolete for at least 15 years...no parts still available, so your best bet will be to replace it. The cheapest option would be a Jabsco manual 29020 for about $100, but don't expect it to last anywhere near as long as your Brydon has...about 5 years is the max they last today. I recommend you go with the Raritan PH II (or PHC--which is the same pump on a compact base--if space is too tight for the PH II), which has been rated the best manual toilet under $500 (it's about $225) for several decades. Your best source for a tank is Ronco Plastics...the make top quality tanks for a very reasonable price and have more than 400 molds to choose from, over 100 of which are non-rectangular. Their catalog is on their website at http://www.ronco-plastics.comHose: SeaLand OdorSafe. It's expensive, but the only hose that's bulletproof against odor permeation. Before you start this project you might want to check out the link below. Several chapters are devoted to installing toilets and holding tanks.
