Hi all,
While tackling the "Bear" of a job changing out the throttle and shifter cables on my '97 MKIII, my ignition switch fell apart in my hands as I attempted to start the engine. I cannot get back to my boat until next week and want to order a new switch. Mine is not mounted on the dash. It is mounted to the side of my pedestal mounted dash pod. The confusion lies with the need of a momentary glow-plug position as it applies to the number of positions required and whether or not I need the "flattened" sides on the switch barrel. None of the usual sources addresses these question. A part number and/or descriptive source would be greatly appreciated.
Incidentally, regarding my control cable change-out; Since I can't seem to remember the proper routing of the cables from the base of the pedestal to the access holes on the left and right sides of the steering compartment. I thought is was a cross-over configuration and was dumb enough not to take a photo to insure I got it right. Now I find the throttle cable is a little short and the shifter cable a little long, only by inches. I think this may be why there is a problem of inches. No, I did not mix the sizes. I carefully measured and marked both cables prior to installation.
I can go on and on with suggestions on how to make this process so much easier but I won't. If anyone needs details of the problems and solutions I found, I will be happy to help.
Thanks all.
Stay well and Happy Sailing....
Thanks all.
