If marina puts or pulls h26 from water without draining ballast, would this break it, or sloshing tip it??
Oct 8, 2023
97
Hunter 260 Kemah
If marina puts or pulls h26 from water without draining ballast, would this hurt it? If they don't move ballast plug. Thought I would ask if there are horror stories of breakage or boats tipping over. Must I not trust the staff to do normal move. Or does water leak around plug and all is fine??? I guess I could leave plug in bottom ALWAYS open inches. Happy winter!!!! - D
Sep 24, 2018
4,545
Catalina 30 MKIII Chicago
Waves will cause more turbulence in the tank than a crane or travel lift. The straps have a large surface area against the hull so it's highly unlikely that your boat will tip in the straps. It's far more likely to fall over from improperly placed stands. A full tank might put extra strain on the hull when it's on a cradle/trailer/stands so I would drain it as soon as you can. Remember, your boat is made to heel and bounce around in waves and on a trailer.
Likes: Timm R Oday25
Jul 7, 2004
8,536
Hunter 30T Cheney, KS
FWIW, my old MacGregor 26S manual said always drain it because the trailer wasn't rated for the weight of the water ballast.
Jun 2, 2004
3,653
If the valve is open when they lift the boat, it just takes i minute for the water to run out.
Do not let them move the boat if the tank is not either full or empty.
The water in a full tank cannot move. Water in a half full tank moving inside the tank creates a tremendous force when it gets to the other end of the tank.
Jun 2, 2004
3,653
But a marina pulling boat in autumn when I am away won't know to drain water....
Open the valve AND the vent before you leave. Advise the marina it is a water ballasted boat and to lift it but wait for the water to drain prior to moving it after lifting it. Make a sign stating that as well mount it to the boat so the lift operator will see it when they lift the boat.
Send an email or have a marina representative sign as having received those instructions and take a picture of the sign on the boat. If there is damage as a result of the water in the ballast tank you will have sufficient evidence that you have done your due diligence, and damage is a result of negligence, indifference or incompetence on the behalf of the marina and or its employees.
Joe
Jun 1, 2004
8,323
Put your requirements, procedures, conditions or any other items that concern you in your contract with the marina. When you schedule your appointment simply go over what and how you want your boat handled and put it in writing. Trust me they will not ignore unless they like getting sued.
-na -NA Anywhere USA
As @Rick Webb highly suggested, leave the drain.open. Also include leaving the air vent open too. As for slings use the 6 inch straps minimum to be aligned with the strap marks decals found under the rub rails It takes2 1/2 minutes for the tank to drain. When lifting the boat out of the water with a boat lift, tell the operator to slowly lift the 26/260 for 2 1/2-3 minutes. It has been suggested to leave written instructions with the marina but my suggestion you watch the boat being lifted out
2,472
I strongly advise you to be there when your boat is hauled or launched unless your marina staff are familiar with your boat and you have a trust relationship. Even then, I agree with prior posters who said to document everything in writing (text is OK) and leave notes on the boat itself.
I always try to be there but (even though I'm there by appointment) I send a reminder text to the yard manager and attach lifting and blocking diagrams scanned from my boat's owners manual.
He appreciates it too - leaves out the guesswork and debate about what's "proper" for support points. It covers his a- if they do it right.
Sep 27, 2008
183
Hunter 33 Danversport, MA
Sorry, Davenport not Danversport.
We got to -12 F here the other night so big life in TX
As Rosanne Rosanna Danna would say...
"Nevermind".
