Engine Compartment (A Better Mouse trap)
Actually, I was concerned about the Engine Compartment. I plan on ripping my original engine/galley sink enclosure out. My Current engine enclosure is about 32" deep 55" wide and 35" high. It has 3 Sides and top with the back wall being a center bulkhead. I plan on building about a 2" square perimeter frame (oak, or mahogany) that can be removed with a few screws. The sides (left, front, right) will be teak plywood. The sides will still have the normal hatches for quick access. But the sides will also be countersunk with protecting countersunk stainless steel washers. These panels will machine screw to the perimeter frame. (Saw the countersunk stainless washers on an Oyster's floor boards this last fall at Annapolis). The top will be marine plywood about 3/4" thick with a sink and a tile surface. The top will be hinged with a piano style hinge attached to the back wall so it can tilt up about 30 degrees. This whole enclosure will allow easy and COMPLETE access to the engine. No more human pretzel manuvering!!!
