Pink foam
I have a '77 C30. I am able to keep blocks for over a week in the summer. I bought 2" thick pink foam insulation from Home Depot and glued it all around, sides & bottom. I even glued it to the inside top. Where I couldn't put foam I sealed with chalking. I also drilled and shot expanding poly foam into areas I couldn't reach. The insulators for the lids help. I also bought one of those survial blankets and folded it over a few times to the shape of the ice box. Lay it over the ice in the box,it wil reduce the area you need to cool down as well as keep the warm air out when you open. Last summer I cruised for 2 weeks and still ha pieces of the original blocks when I got back. Also, put a loop in the drain hose under the box. This will form a "plug" as the ice melts and kkep warm air out.
