I'm in the process of converting my ice box to a fridge. I read some forums about it and now on the go. I found out, as said in the forums, that there was some insulation missing at the bottom, well those who said that where right, specifically on the rear left side but most of all, the top part. There's a part that can be taken off, that covers the entire box, that had tge stuff they use in flower shops to stick flowers for funeral homes !!!
I'm cutting 6" off the bottom, (the lady is sick and tired of reaching that low), wich will give me some room to add insulation under. I'll be moving it a little to starboard and to the back so I'll add an inch of insulation all around to make it 4" min.
My question is : Should I keep the actual insulation and cover it with new one or take it all off and go with new material ??? I'll be using insulating panels that as aluminium foil on both sides, found at Home Depot, R7 /inch.
Thanks for your ideas.
André
P.S. I'll put some pictures after my work will be done.
André
