Usually in the strut, there is a brass and rubber bearing in which the shaft passes through. If the bearing is worn, you will get some play. Remove the castle nut and prop, and then remove the cutlass bearing. Replace with a new one. Replace prop and nut and of course the key and cotter pin.
