Where can I find/locate the cap for the water strainer/filter so I can look and insure there isn't any debris or seaweed infiltrating? Having a dickens of a time locating it. My engine is the 18 hp 2 GM. Thanks, Mike from Gig Harbor
You are welcome. I did that with all my thru hulls. Got a good yoga session at the same timeI'll check, thank you Justin
You da man DD! Went thru 60 pages to find it. Mine is located right about the same place. I guess it's wise to be close to the center line and not get cavitation.pg 60 will give you a location
https://www.marlow-hunter.com/wp-content/export/Owners-Manuals/280_owners_manual.pdf
