I have a 1986 O'Day 222 that I bought new in a boat show. It has a 27' Z-190 Z-Difusion Aluminum mast with internal halyards. This is my second mast. The first on bit the dust back in the mid 90s off Newport RI.
When I had this mast made up by a rigger, I had them install a Kenyon hinged tabernacle top plate hinge plate, plus a fabricated stainless steel mast plug which I believe caused the bottom of my mast to corrode over the years. I mounted the lower hinge and the utility plate on a piece of 1" thick Teak to the cabin top myself.
Last summer I had to cut 2" off the bottom of my mast. I had to use the same mast plug over again in order to keep using my boat. I made up the two inches by using two 1" pieces of Trex.
It works, but it's too heavy and it looks a little hacky.
I need to eliminate that mast plug and go with something light and strong.
My plan is to cut out a piece of Trex that will fit into the mast and bolt it to a 1/4" Aluminum plate. I could use five wood screws through the side of the mast to secure the Trex block. The Aluminum plate can take the weight of the mast and could overlap it about 1/4" all the way around which could cut down on the weight.
My problem is; What material could I use between the 1/4" plate and the top tabernacle hinge plate?
Shortening my stays is out of the question. I have a CDI Roller Furler mounted on a 5" tang on my bow stem chain plate which provides clearance needed under the drum for my bow anchor roller.
I'm posting pics of this monstrosity so you can understand my problem. The company that mfg this mast is out of business. I used to have the old bent up mast years ago but like and idiot, I gave to some guy who wanted it for scrap metal.
The trex on the cabin top under the lower lower hinge and utility plate is permanent. I had originally mounted the lower hing plate and utility plate on a 1" thick Teak board back in the 90s, but that's another story.
At any rate, if anyone has any ideas please chime in.
