Oh well, it could be worse.
Tony,The rudder body was made by: (previous owners of my 23 never through anything away)Foss Form, Inc.Phone (12yrs old)813-577-0478Clearwater, FloridaConstruction is F/G shell filled with Urethane plastic.It is one expensive item. The rudder box is another issue. Hunter Marine may be able to help but expect more expense.Tillers are available as a special order item from West (read, we'll make one after you pay for it) The transom hardware (gudgeons on transom pintles welder to rudder box, I believe) is probably available from West. You may want to check the transom carefully as it is a weak point on the 23.All together, replacement rudders are a costly proposition. I hope the price break you got on the boat was sufficient. Greg
