The big problem...
The big problem with Ideal type hose clamps is that they rarely, if ever, fail like some would think they should. Ideal type clamps DON'T usually fail with the band breaking as some stereotypically think is a catastrophic failure. The failure of Ideal, or any other clamp that has the slots in the band, is usually in the screw mechanism. Many times from hoses becoming hard and the forces of expansion & contraction I have seen the threads of the tightening screw pop free from the "slots" in the band. When I check Ideal hose clamps I put some pressure on the nut driver. This is by feel so you guys will have to know what that is for yourselves but it's less than the original torque you used to install them in the first place. Many times over the years when I've done this the tightening screw has "stripped". In reality the bolt does not actually strip but that's how it feels through the nut driver. What is actually happening is that the cap, the part that says "Ideal" on it, and barrel that hold the screw in place, to the band, have become stressed, lost strength, and allowed the threads of the screw to be pushed up and out of the "slots" in the band!The above description is a FAILED hose clamp! If your looking for "snapped" clamps as your idea of a catastrophic failure your over thinking it. The more common failure of the screw is much less exciting! this form of failure is one that's often NEVER noticed until it's leaking. Unfortunately when most boaters check clamps they don not do a torque test and only look for a snapped clamp... It is for this reason that I now only used AWAB "smooth band clamps" http://www.awabllc.com/ where the forces of the hard hose are not also working against forcing the threads of the screw up and out of the "slots"..I hope this helps describe hose clamp "failures" a little better...
