I have a Catalina 34. Wanting to upgrade my alternator. The Catalina site shows a prestolite 105 they say will work. Any input, ideas?
There is more to upgrading an alternator than just installing a new larger one.
There will be little advantage to the larger alternator if it is an internally regulated alternator. The internal regulators are typically not set up for charging deeply discharged batteries and are not adjustable for different battery chemistries.
A 3/8 inch single belt is not sufficient to drive the alternator without a lot of belt wear. At 90-100 amp it is necessary to move to a double belt or serpentine belt. The larger alternator will also place more pressure on the adjusting bolt causing it to slip.
The articles on MarineHowto.com provide a good overview.
MarineHowTo.com - Alterntors & Regulators
Likes: JoeWhite
Feb 6, 1998
11,760
Wondering if I need to change anything like a pulley?
If you want to use that Chinese clone alternator from CD you'll need to convert it to external regulation as the 3/8" belt is going to really suffer. This is why we build our CMI-72-IR model..
Mar 6, 2008
1,503
It also will require additional horse power that is provided by the engine. The original alternator generates about 14.2 vdc and I have monitored as much as 21 amps.
J Spry
Jun 17, 2021
5
catalina 2006 Catalina 34 Safe Cove
I just left my info with them. I will see what they suggest. Thanks
J Spry
Jun 17, 2021
5
Thank you I will follow up.
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
If you decide you want to add a serpentine pulley, you might want to check the clearance on your engine cover. If I remember correctly, the install is similar to my Cat 320. I added the serpentine pulley to my 125 amp alternator (previous owner upgrade) and found the pulley rubs the inside of the cover until I pulled the cover out an inch. I haven't worked out my solution yet (I'm just living with the inch gap this summer) and I suspect that the P.O. didn't buy the serpentine pulley for that reason.
J Spry
Jun 17, 2021
5
Thanks. I was wondering if that might be a problem. There isn’t a lot of room as it is.
MitchM
Jan 20, 2005
1,031
i'm familiar with a few yanmar owners who decided to 'upgrade' their alts from the stock that yan put on as OEMs. they hd nothing but trouble. so check your engine mfgr's specs VERY carefully to avoid a lot of untold aggravation. mainesail is right . (as usual...)
NYSail
Jan 6, 2006
3,184
Beneteau 423 Mt. Sinai, NY
Speak with Maine Sail. I followed his recommendations and my upgraded alt that I purchased from him works as advertised. Yanmar 4JH4E……
good luck
Greg
