I Hate Birds
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
JungleJetJock
Just curious about your avatar, is it someone's eye in negative?
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
JungleJetJock
Dec 3, 2003
2,101
Use a Tarp...
...over the dodger and bimini. It's quick to remove and set up. Use it until you find a way to control the birds.
Dec 3, 2003
2,101
Use a Tarp...
Ron M
All great ideas
These are all great ideas. If you're not going to use your boat for a period, try tying mono line between the fixed rigging, boom, and aft sections (anywhere they're likely to fly/approach to land). They don't like flying into line and will avoid your boat, in short time. We have mono tied across the top of our pool area in a random nature. Not even ducks will attempt to use the pool as a resting stop.
Ron M
All great ideas
SV Tumbleweed
Electronics works
Electronic devices will repel your birds however, the units start at about $400.00 USD Fair Winds, Bill
Rick Sylvester
Tell us more Bill
What device are you referring to? A nearby marina installed a box that blasts loud noises of some kind that supposedly would scare off the birds. We don't know if it worked though, it was so obnoxious all the people left :) We've jokingly talked about wiring some shore power to zap the rig periodically. Probably easier to clean bird carcasses off the deck rather than their poop...
jebenz
Jun 2, 2004
14
Hunter 37 New Orleans, Louisiana
Bye Bye Blackbirds
I hate birds too. West Marine sells a string of signal flags sewn to a nylon tape that can be run up the mast with the halyards. The cost is about $30.00. One string should do but if not two surly will. Tie them off either at the stern and/or foward at the bow. The flapping flags should keet the birds away and the boat will look nautical, good luck.
jebenz
Jun 2, 2004
14
Bye Bye Blackbirds
