I have a 1978 Hunter 30 with a Yanmar YSB 12 engine. I just bought the boat and had the engine gone through, with all wearable parts (belts, hoses, etc.) replaced. On our sea trials the engine quit after a couple of hours, then started after twiddling with the fuel pump, then quit again. The fuel pump was pretty weak (barely ticking when the ignition was on,) so I replaced it after this trip. The new pump is much stronger and sounds fine, but our first trip out after the new pump was installed -- same thing, stalled after about 15 minutes.The float bowl in the Racor filter (with new element) is clear, and all hoses were replaced and are double-clamped so they all appear to be air tight. Any other ideas? I don't want to just replace parts, I'd rather trouble-shoot, but the engine manual wasn't much help.Thanks in advance!Casey
