I-Beam between compression post and keel
O
Owen Trepanier
I noticed the I-beam between my keel and compression post is sort of delaminating (if steel can do that) as it rusts. It has burst it's fiberglass coating wide open and now only has about .5 cm of solid thickness left intact. I would like to know how to replace it, what it might cost, and what I should be concerned about. I am planning to sail from Fort Lauderdale to Key West (~150 mi) at the end of the month. Is this something that I need to correct first? And, does it have to be hauled to do it? Thanks, Owen
E
Ed Schenck
Forum archives.
There were 75 "hits" for "compression post" in 1999 alone. See Link below for one example.
Bob Howie
Compression post I-beam repairs
I had/have the same problem with my Hunter 30. The "Perfect World" repair is to decommission the boat -- pull the mast -- to take the weight off the compression post. Support the compression post and remove the I-beam. Replace the I-beam with a stainless steel pipe section welded between two pieces of SS plate and then reinstall that. Chances are pretty good this little assembly will outlive the boat!! You and me both, probably! When my yard told me it would be about $3k to do the work, I kinda laughed and asked what their second opinion was. What we did, at least for an interim fix, is to leave what is remaining of the I-beam in place and chock either side of it from the base of the compression post to the keel with dense wood with little compressibility; quarter-sawed oak in this instance. We drilled through the plywood plate at the base of the compression post and snugged the oak in place with SS wood screws. This should support the weight of the mast for the time being. Ok; so what's the risk if you don't do anything? Well, about the time the I-beam was installed, it was more or less new and possessed a known engineering strength. If it's delaminating, and mine did, too, then it no longer carries its former load rating. What you have is an unknown quantity there which will support only God knows what weight. This could possibly lead to a failure of the I-beam, or what's left of it, which would then essentially place all the weight of the mast on the deck, which would most likely fail too, causing you to possibly dismast the boat. I'm no engineer, but I have been around boats all my life having grown up on a coast and started sailing at an early age. If I can be of any more help, let me know, but you should really have an expert take a look at this. It's not something you want to let just go. Hope this helps.
O
Owen Trepanier
Thank you
Thank you. You both have given me help I appreciate very much.
Bob Howie
A good idea on the compression post
Owen, Read the archives on this and there's a really good idea for a permanent fix that I may adopt for my boat. Remove the wooden compression post and the I-beam. Replace that entire span from the coach house roof to the keel with a solid stainless steel post with 1/4" stainless steel plates on the top and bottom of the post. This removes 2 separate pieces in exchange for a solid section that will generally be impervious for a long time. It's a good idea worth considering. The chocks I mentioned in the first e-mail will work for awhile and should cover your planned trip to Key West. Regards, Bob
