I am thinking of buying a Hunter 33 "78-83'
tom manalili
33 facts
the 33 hunter designed originally for his brothr's custom boatyard in Jersey, this happens to be one of thr very best hull designs, of all time, his brothern had 2 deck layouts, one for racing one for cruisingthr hunter33 is the cruiser, she's narrower that ken palmer's 33.5, and may have initial lean to start with, but if your not looking for a condo, it would take little effort to make her a solo sailer, but then again, you my like a boat with another 1&1/2 of free bpard and a stern or back side that would embarrass any woman. and your getting a sleek boat,great sailing boat at half the price of a floating condo. best wishes girl, knock em dead.
tom manalili
33 facts
Sam Lust
My 1983 H 33
We've had our Hunter 33 for about 6 years now. Ours appears to be the last production 33 sold as a Hunter. There were a few later hulls sold as "Quest" kits. Generally I like the boat a lot. I like the layout. Possibly my favorite layout feature is the aft head. Close to the companion way, enough head room for me to stand up, and my absolute favorite, the toilet facing fore/aft, rather than across. Much more comfortable and a lot more secure to use under way than a center facing toilet. Don't tell anyone this, but I actually got thrown off the toilet of a Catalina 27 while under way in somewhat rough conditions. We hit an odd wave on starboard tack and I got spit off the throne and onto the cabin sole. Doesn't do too much for your dignity at all. The boat is fairly well put together and for the money they draw they're usually a great deal. There are very few inherent problems associated with the boat. Contrary to another thread currently running, the 33 is not known to throw off it's own keel. I slammed into an under water concrete abutment at maybe three knots, the boat stopped instantly, and aside from a wee bit of lead moved around on the keel there was no damage. Luckily my wife didn't break any woodwork as she flew from the top of the companionway to the cabin sole. Her foot has healed nicely by now. The cockpit works well for single-handing, with the winch pods close at hand. I essentially single-hand any time my wife and I are out and I have no problems. Tacking to windward is a breeze, if you'll pardon the expression.. The down side of that convenience is that due to the intrusion of the winch pods the cockpit benches are too short to sleep on. Not much of anywhere to sleep out on deck for that matter. We over-nighted one Fourth of July when it was about 110 degrees. Absolutely could not remain below. I ended up on a cushion on the forward portion of the coach roof worried about rolling off. I guess one hour of sleep was enough. Among the few noted problems is a tendency for the rudder packing nut to corrode out to the point where it will allow water through. In your case I'd suggest you stick with the later, squared cabin design. I believe 1980 or later, although it may have changed in '79. There appears to be a couple if inches more head room at the aft end, and certainly more at the forward end where you enter the V berth. Another possible weak point, depending on your point of view is the Bomar ports. Not so much the ports but Hunter's shoddy installation of them. They tend to let water in which runs down to the outside walls, then on down to wherever it ends up. Sometimes it weakens core, sometimes not. Easily fixed by proper re-installation or replacement. If you get a typical un-upgraded boat you'll likely end up replacing the head, fighting with installing a decent holding tank. The original fresh water pump can be repaired but isn't worth it. You'll want better sails, with 2 reef points on the main. The later models came with a Yanmar 2GM (2 cylinder) which was sea water (raw water) cooled and at 13/15 hp was barely adequate. The 24/27 hp 3GM30F (3 cylinder) does a much better job Don't expect the shoal, 4' draft version to sail up to the reputation of the deeper 5'3" version. It simply won't. But then you'll sail loads of places they'll only dream of or dinghy into. Many of the shoal owners here seem to agree it's very sensitive to sail trim. But when you get it into a groove it goes great. I could go on but I think you get the idea. I have been into every nook and cranny on the boat so I'm as familiar with it's intimate parts as you can get. (I think I'd pay good money to watch you wiggle in to work on the rudder packing nut!) If you end up with one feel free to fire out questions.
MOE HORENFELDT
Hunter 33 (19810
I bought ken Palmer's boat and motor-sailed it through 3-5 meter waves, trying to get it back to Toronto from Rochester in one day in September. That experience made me a believer in the solid construction of the boat. The room below for an "older" boat is fantastic, and the only additions I made were to add a dodger, 12 volt refrigeration, and dighy davits aft. The boat sails well, is a bit underpowered heading into seas, but will really impress most viewers, and crew. Go 4 it!
joegooch@hotmail.com
A Lot of Boat for the Dollar
Julie, The move from a Hunter 28 to a 33 was a very good one. The 33 is a lot of boat for the buck. A three-blade prop will help the power; but the 15 horse Yanmar is adequate with the added prop. A new head is probably a good idea. The cabin is comfortable and homey; you do not feel you have to conform to it; it conforms to you. The nut on the rudder may leak, but so what, fix it. Any boat 25 years old will need some repairs but don't all boats? So, paint it up, sand and varnish the sole, do some repairs and you will have a very nice dependable good looking boat. Enjoy! Joe
E
ernie
Simply put...
This boat is a dream you won't want to wake from!! The few design problems that may arise are no competition for the sheer joy of sailing her!
R Dunn
Jun 7, 2004
3
Hunter 33_77-83 League City, TX
Great boat....
Julie - I bought my 1982 last summer in South Padre Island and sailed it back to Houston (300+ miles), both offshore and in the ICW. The boat handled great and there is plenty of room onboard. I have done quite a bit of sprucing up and we currently sail it in Galveston Bay. Make sure you have it surveyed and if it is in good shape....buy and enjoy. Randy
Hunter 33_77-83 Lake Lanier GA
We love ours...
This is Freebird. She has been ours for 23 years, we have been her only owners and plan to keep it that way. This is one boat that I can see keeping forever. I really mean that. Ours has never been in salt, but she has been in very high wind and performed wonderfuly. I single handle her all the time, an autopilot would be something to have if you plan to do that. WP-30 fits her nicely. Older boats are in many different conditions. If her previous owners have taken good care of her, preformed maintance in advance of problems.. then she should be a great boat for you. Mine is shoal keel, a deeper keel will improve pionting to the wind but keep you out of some areas otherwise availalble with a 4 foot draft. Sometimes I would rather have the deeper draft to protect the rudder from grounding... my rudder is close to the same depth as the keel. But my rudder is the original and still doing just fine. Lots can be done to improve the interior and deck, but straight out of the box she's a comfortable well made boat. Good luck. David Underwood s/v Freebird (Hunter 33, 1982 model)
We love ours...
Our boat is named is Freebird. She has been ours for 23 years, we have been her only owners and plan to keep it that way. This is one boat that I can see keeping forever. I really mean that. Ours has never been in salt, but she has been in very high wind and performed wonderfuly. I single handle her all the time, an autopilot would be something to have if you plan to do that. WP-30 fits her nicely. Older boats are in many different conditions. If the previous owners of the 33 you are considering, have taken good care of her, preformed maintance in advance of problems.. then she should be a great boat for you. Ours is a shoal keel, a deeper keel will improve pionting to the wind but keep you out of some areas otherwise availalble with a 4 foot draft. Sometimes I would rather have the deeper draft to protect the rudder from grounding... my rudder is close to the same depth as the keel. But my rudder is the original and still doing just fine. Lots can be done to improve the interior and deck, but straight out of the box she's a comfortable well made boat. you might look up an older article about one owner that sailed from Tampa area to the Dry Tortugas (spelling?) and back.. good article that will give you some idea of how she preforms in weather. Good luck. David Underwood s/v Freebird (Hunter 33, 1982 model)
