I am Stuck on Standing Rigging
Jul 22, 2011
146
Mariner Yacht Co.(NH) Mariner 28 Atlantic Highlands, NJ
Call Catalina. They are very supportive of the C 30 community, and I suspect they might have done some cocktail napkin type calculations on what standing rigging sizes should be. I second or third the Rigger's Apprentice suggestion. Rigging is a system, and making one part of the system bigger most likely leads to imbalance not greater system strength.
Apr 5, 2009
2,819
You also have the choice of different grades of wire.
1/4" 316 SS 1x19 wire rope, minimum break strength 6900lbs, $2.00/ft
1/4" 304 SS 1x19 wire rope, minimum break strength 8200lbs, $1.57/ft
1/4" Nitronic 50 rod rigging, minimum break strength 10300lbs, ?$/ft
Nov 8, 2010
11,386
The max strain/load that your rig can ever be at is at a point well known to the designers. And they size the rigging accordingly. There’s no reason to upsize. Just maintain it and you’ll be fine.
Stick to SS. PBO is a needless and unnecessary expense on the Catalina 30.
