I am looking for a good WiFi antenna setup
252
hunter 260 Ruedi Res.
Has anyone used the Radiolab WaveRV antenna? See the link. Seems like a good solution, eliminates the coax line loss issue. I am looking for any input. Thanks.
Feb 5, 2008
37
CS CS30 Toronto
A lot cheaper solution
(1) You can use a USB-KEY WiFi and hoist it up higher. That's basically what this thing is but cost 90% less. (2) If you want to be fancy and look impressive, stuff one inside a fiberglass tube or old VHF antenna (which is hollow). I use method one above as I don't surf and sail at the same time ;-) My $0.02.
Rick I
Jan 6, 2007
414
CS36Merlin and Beneteau 393 - Toronto
Here's what I've been using this year
Working real well. gets signals miles away. Am writing this at anchor in Georgetown, Exuma miles from the closest wifi signal. http://www.netgate.com/product_info.php?cPath=26_42&products_id=328 Netgate First season with it. No need to lug the laptop ashore anywhere.
Dec 2, 1999
15,184
Don't know about that price!
Check this out! I believe it is the same unit for $41. http://www.keenansystems.com/store/catalog/default.php?cPath=2&osCsid=2d126726fea4f620ab38b096b6913b50
RichH
Feb 14, 2005
4,773
I use the Radio Lab RV marinized.......
I use a Mac and the marinized WaveRV. that you listed. Running the NE and mid Atlanitc Coast I can usually 'hit' any non-encrypted open wireless modem from about 1-2 miles offshore. The growing problem is the surge of 'subscription for price' nodes in popular anchorages/ports (in which most formerly open modems, now seem to have all turned their encryption on). Usually near any high density population area someone is bound to not be encrypted. The marinized WaveRV is a good unit; but, do get the self-powered extension cable if you need more length than supplied with antenna .,... to get the antenna as HIGH as possible. ;-)
Jun 2, 2004
3,650
Works Great
We put one on a neighbors 49' DeFever trawler. He just left Martinique headed south I was on the boat as far as Marathon. We never were in a marina or an anchorage that we could not pick up a signal. As he went further south WiFi spots became further apart but he still gets a signal when others around him have none.
Kirie-Elite Elite 37 Niceville, FL
Wi-Fi antenna
I use a NetGear extended range USB antenna (69.99) and a 10' usb extension cord.(16.99). It worked great in most locations (Abaco's, Georgetown etc.) It costs less. I just put it in a plastic baggie and hoist it up the shrouds as high as I can get it. Not quite as effective as the specialized antenna, but it worked great for us.
Jun 3, 2004
730
Catalina 250 Wing Keel Eugene, OR
What about 802.11n?
802.11n is the emerging WiFi protocol. Will this antenna support that??
