Hunter Wiring Compass
361
Hunter 30 Middle River MD
Got back my compass after a rebuild by Viking. They did a great job no way would you know its the same compass that came with the boat.
Now a question, as I went to wire up its lighting I came across a somewhat unusual color coding. The compass has traditional red and black leads, but the pedestal is either brown and green or red and green. I am assuming the brown wire started life as red.
If so I am guessing the green is ground and the "red" is the hot side of the circuit. I do realize as the wire is in fairly good shape there is no reason to believe its original. Thirty years on the water and I would have expected the insulation to be dried out and stiff.
Thoughts?
Jun 2, 2004
5,802
I have had my binnacle apart but sure do not remember the wire colors. I would just put a multi-meter to the wires. I think the wires go into a harness so you will never be able to trace them.
Jun 9, 2008
1,852
- -- -Bayfield
Polarity is not important when you are supplying 12v juice to a 12v light bulb. It will work regardless of how you wire it up. Not true with a motor (which will run backwards if wired backwards).
Jul 7, 2009
252
Beneteau First 405 Myrtle Beach, S.C.
Barnacle Bill is correct. The light bulb will light up regardless of polarity. However if there is an L.E.D. instead of a bulb, it will light up one way and not the other way. Just a matter of reversing the wires if it does not light up.
Cheers
Aug 23, 2009
361
Follow Up
Cheers
Yup knew bulbs didn't care but know LED's can behave differently I know some will change color with reverse polarity others not light, just wasn't sure if some fry when reversed. Would be a shame now that you could actually read the compass to blow the new LED light if that were a real risk.
Thanks everyone.
