My 146 hasnt flipped yet
LTJohnston...I have not yet even flipped this boat - means  I can't comment on whether she will turtle or not once she does flip.The beam on this boat is 6.5' - fairly beamy, which means more stability.I have had the rail buried lots this season, and just the other day, somehow heeled so far over that the benchback must've been just under - when she flattened back out, she scooped water into the cockpit from the side!  Point is, even pushed that far over by a shifty gust, this boat flattened back out instead of continuing over (with a sharp push to leeward on the tiller, of course!).I singlehand a lot, and am happy to say that by myself, I don't suppply much ballast - just one other crew member helps her sail flatter.I do plan on foaming the mast at the end of the season, which many 170 owners have done, just to be extra safe.  Check the archives on "foaming" - there is lots of discussion, instructions, and test results.Next season I will flip her on purpose, which is always smart to do (shoulda done it in August while in the bathtub-warm, shallow waters of Cape Code Bay!)On a boat this size, you know flipping is inevitable - however, you don't want to turtle and stick the mast.
