Hunter Vision 32 motor mount size, vibration, white smoke
Feb 2, 2021
3
Hunter Vision 32 Edgewater Marina
I think I have every possible problem with this 3gm30f lol.
First I'll start with:
1. Can someone with a Hunter Vision 32 confirm all 4 of their motor mount sizes for a sanity check on my part? I have 100s on all 4.
2. When starting, I get a ton of vibration and clanking (as it starts on 1cyl and within about 10sec or so, works up to all 3). I am familiar with the GM series yanmars, but the clanking/vibration aft of the motor is new to me. I checked the prop, cutlass, etc. The only thing I found were 2 loose bolts on the coupler, which vibrated loose recently. It does the typical vibration at certain RPMs when under way, which is fine. But I am 95% sure that the clanking I am hearing is the prop shaft(in neutral) vibrating against the through hull fitting. It shakes the whole stern and there really isn't anything else it can be. I read you can't REALLY tell if a motor mount is bad by pushing the engine back and forth, but it does move semi-easily. I plan on replacing them, but does everyone agree with my assessment?
3.I can't shake this hard starting/white smoke thing. I've read 100s of threads on it and tried almost everything. There is 1 cylinder that doesn't want to start firing until it's warmed uparound 1-2min from starting. There is a decent amount of white smoke at startup, which can be kind of normal. It eventually goes away mostly at idle. It is smoke, not water vapor. Then when i motor out around 2600rpm it comes back. There is no noticeable blowby, which tells me i don't have a significant compression issue. If I open the compression release within about 5min of starting, cyl1 makes no difference. When it is warmed up, it does make a difference. I checked valve clearances. I cleaned all injectors, checked with a pop tester at home, then took each one on the boat, mounted it to high pressure side of pump and flipped it upside down so I could confirm the pump is working. Each had a pattern close enough that I couldn't tell the difference. And I also swapped injectors 1 and 2 to make sure that 1 cylinder didn't have an injector issue. I replaced the lift pump. I replaced the mixing elbow. No water in oil/oil in water. Changed both fuel filters, air filter. Bled lines multiple times. Replaced every crush washer. pressure tested the lines. The only thing that I have not done was pulled the valves on top of the fuel pump and cleaned them. Or rebuilt the fuel pump. But that would be odd because all of the injectors seem to give a nice pattern of fuel, as best I can tell. Would a slightly less than perfect injector pattern cause it to not want to fire the way it should and the white smoke? I suppose I should do a compression test, but I feel like I would have blowby if there were issues.
Sep 4, 2007
795
Hunter 33.5 Elbow, Saskatchwen, Can.
You might have a burnt valve that's not sitting right. A compression test or leak down test will show if that's the case.
Feb 2, 2021
3
I assumed I would have some blowby if that were the case, but I'll go ahead of do a compression test. At least I'll know for sure that way.
Feb 2, 2021
3
Welcome to the site.
Blowby is caused by a leaking piston ring. @Don Crowther mentions a leaking valve(s) on one cylinder which blows to exhaust.
I still see a compression test in your future.
Good point, and that would explain some of the white smoke too. I'll post the results when I do it. Thanks all.
Nov 6, 2006
10,256
Best to check the valve clearance before a compression check . Could be a bad injector as well.
The motor mounts are 100 front and back on that engine.1245772-08341 is the part number.. They are kinda soft so that the three cylinder shaking is not transmitted to the boat as much.
Likes: sharkcus
