Hunter Trailer
37
Hunter h26 Orange
Does anyone have the trailer specs. for a 1996 Hunter h26? I need to modify a trailer I have to fit a boat I am purchasing. Thanks, P Evans
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Jet, my first suggestion to you is to contact Hunter and see if they have the drawings for the cradle on file. I believe they should. If they do they can email them to you and you can modify your trailer according to those dimensions.
Nodak
-na -NA Anywhere USA
The trailer was designed to the boat with long bunk boards. Make sure you have four supports and dual axle with a keel tray for the centerboard to rest on ( make sure about this). If you can locate a Hunter 260 trailer, then copy that as it is the same hull as the 26. You might try contacting Magic Tilt as they built the trailers for the 260 but your trailer was built by Hunter itself. However, if you have never done this before, I would suggest buying a new one. Road King via sailors trailers has the specs for a new trailer but doubt they will share plans from a liabiltiy stand point. They can sell you one. As for me, this is good advice to you sir. I was involved with the Hunter water ballast boats to include the 26 to include the buidling of the trailer
crazy dave
Dec 2, 2010
37
Hunter h26 Orange
Thank (yawl) for the info. Hope moving up to the H26 turns out to be a good choice. I have looked at numerous boats before making this decision! I was kind of partial to the Seaward but it just wasnt in the budget. Thanks from Texas
