Hunter Rub Rail at the sugar scoop (swim deck)
Aug 19, 2021
508
Hunter 280 White House Cove Marina
I was just told that the rub rail all hunter sailboats submerges at the sugar scoop (swim Deck) while underway.
Is this true?
Jan 4, 2006
7,262
Is this true?
For you and me it's true. Any reason for your concern ?
If you look on the interior of your hull, you will see that the stretch that of rub rail coincides with this portion is heavily covered in fiberglass to avoid the possibility of a leak between the flanges.
If I were you, I'd go back and smack the guy who told your that. Just for giving you sleepless nights.
Aug 19, 2021
508
No not for me. I am a day sailor and there is a good chance I am under loaded.
This was posted on a hunter owners page on Facebook and started my pondering. Since I do not trust anyone on Facebook. I thought I would seek out wisdom here
OP
A bit of a situation. Kind of a scary one. Just finished sailing across the Indian Ocean. On my 44DD. From Indonesia to Maritious. I have had a small leak for about 6 months. Filling the bilge every week or so. During the passage the issue got far worse filling every hour. I thought I had it sorted but was not what so thought. I checked every possible way sea water could find its way onboard. Could not sort it. As you can notice my boat sits low in the water. It’s actually high at the moment. Fuel and water empty plus dinghy is on the bow. About a year ago the stainless strip that accents over the rub rail started to detach. The screws started coming out. On both sides. I was told this was just astetic and not a problem. Turns out that is not the case. I am leaking from the seem into the stern locker. As I have been sitting in a 5 meter seas off the beam twisting the hull for weeks I am very lucky this went from a drip to a slow leek and not a giant crack! Sink the boat in the middle of the ocean. I know other people have had this issue on this thread. I am in a boat yard now. Up on the hard tomorrow. Looking for solutions with rub rail in the water? Seal the whole thing? Bottom paint the stern? Any suggestions? I am circumnavigating. Have a lot of gear. It is evenly dispersed. I have tried moving things around. The boat is just not intended to have this much weight. There is no not being low in the water.
Follow up
all of our vessels, no matter the model sink down with rub rails are underwater.
My 410 is out of the water.
As soon as I am under sail or motor, all of our displacement hulls sink down. And the faster you go, the farther down you sink
Many of our models transoms are underwater, even empty, and at the slip
Many Beneteau’s including the 473 and 423 are underwater at rest.
I find it bizarre the global trotting sailors would overload the boat and seek solutions other than offload some stuff...
I have never seen my rub rail at the swim deck or sugar scoop in the water let alone under the water.
It is like Ron White says "you can not fix stupid"
7,262
Take a look when your under way and watch other Hunters as they go by.
A friend of mine has a 34 ft. Cat and it squats as well. Out of the water when not moving. Same maneuvers as my H-310.
Aug 19, 2021
508
I will have to pay more attention.
My 340 does. Never been an issue for me, but it is noticeable.
Well team, I think i learn something here today. That said, I still do not trust anything I read on Facebook.
Thx a million.
Jan 7, 2011
5,589
Oday 322 East Chicago, IN
Most sail boats “squat” when under sail or motoring.
My O’Day 322 certainly does. I have several thruhulls (no valves) for scuppers and LPG lockers above the static waterline (but below when sailing or motoring). I will have to remember to stop the boat if any of these start leaking!
Greg
Jun 25, 2004
490
Hunter 306 Pasadena MD
Yes: my 306 rub rail is out of the water when at the slip, but is basically submerged when under motor. Probably when under sail as well, but I don't tend to look at it then... I've had the rub rail off and re-sealed it in the past 4 years: the rear 1/3 in 2020, and the front 2/3 last year (or maybe 2022?). Mainly, I have rainwater leaks.
Nov 8, 2007
1,590
At hull speed, the wave/wake along the side of the boat is the same length as the waterline of the boat. The boat sits in the trough of the wave, requiring a lot of power to get to plane out on the wave at its bow. At hull speed, the wave at the stern often submerges drains on the stern. On our boat, the cockpit gets about a half inch of water from the cockpit drains. This means we are sailing fast!
This phenomenon could be part of the reason your aft deck rails are flooding
Dec 4, 2023
138
Hunter 44 Portsmouth
I saw that post come up on Facebook. I have also experienced a little bit of leaking in that same aft locker area through the hull-deck joint. It was barely noticeable, I had wondered why things tended to rust and grow mold so fast back there. A surveyor pointed it out to me that had seen the problem before during an insurance survey a couple of years back.
I lightly sanded the area at the seam, cleaned it with alcohol, and filled it generously with thickened epoxy. So far so good.
