Hunter owners talking about losing their rudder.
bortiz
Sep 2, 2017
7
hunter 430 san diego
Recently i have been reading accounts of other Hunter owners losing their rudders. We have a 95' 430 Legend. Has anybody else who owns one ever had any problems with your rudder. ?
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
Where do they separate? I have mine off right now to remove the propshaft. The only thing I plan to do different is put a new locknut on the bolt that pins it to the quadrant. I could see that bolt maybe working it's way out and dropping the rudder
7,752
Alden 50 Sarasota, Florida
I infer from reading some second-hand stories the problem isn't the rubber but rather the composite rudder shaft Hunter put on the 420 series models.
Dec 14, 2011
316
Navicula 430 Hunter Toronto
I have the same boat....no problem....every yaer I put it on the hard I drill 2 holes in it and let the water drip out....when I put it back in I fill with epoxy and sand
May 27, 2004
2,059
39 years and no problem. Guess they used better materials in 1979.
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
I read in another forum that they are breaking off right at the hull. I only skimmed the article but seemed to remember they were replacing the shaft with stainless steel.
Likes: Dave Groshong
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
My 2007 H-36 has a solid stainless rudder shaft,I think they started the change 05 or 06.
Nick
JamesG161
Feb 14, 2014
8,111
Hunter 430 Waveland, MS
Mine is SS and basically sealed from corrosion [ours hit the water 4/22/1999].
I have a AgCl corrosion reference probe. I checked the rudder shaft for corrosion.
It is NOT electrically connected to the water.
That leaves only the Mechanical connection to the boat, which I inspect annually.
I had mine visually inspected after we were caught in a Squall in shallow waters. The boat was raised up on a 6 foot wave and slammed down on a sandy bottom. No damage:clap:
Jim...
Jul 25, 2004
363
Hunter 42 currently in New Zealand
Hi BOrtiz--I have a 1991 Passage 42, and I suspect that our hulls and rudders are very similar if not identical. About five years ago I had to replace my lower rudder bearing due to ordinary wear (after about 50,000 miles), and I had a marine engineer do a cold-test (with dye) on our stainless steel rudder shaft while it was out. Despite a couple of groundings on the leading bottom corner of the rudder over the years, it was just fine. I wouldn't be surprised if yours was in the same condition.
Dec 19, 2006
5,836
My rudder is solid SS and have seen a few Hunter rudders
were SS but hollow not solid,is that the case with above posted
with SS rudders.
Nick
Jul 25, 2004
363
with SS rudders.
Nick
Yes, Nick---mine is a 4 inch wide rudder post, and it is hollow. I can't remember the thickness offhand.
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
My 1996 H376 rudder has a composite 6" at base and 4" at quadrant. It is hollow but with walls about 1/2" thick. Hunter said it was designed to withstand 10,000 lbs but also to break off in a collision instead of bending a SS shaft. Theory goes, bent shaft with the rudder stuck in the wrong position is worse than a missing rudder. I figure my rudder has about 40k miles on it and still in great shape.
Luigi
Sep 2, 2017
4
Hunter Legend 43 Sydney
Hi Bortiz,
I have a 1991 Legend 43 and the rudder tube seems to have free itself from the lazarette. Which means a lot or re-coring and fiber glass work. I imagine the steering systems between the 43 and the 430 may be very similar (aside from the fact that my shaft is SS) and I am chasing a diagram of the entire steering section before I take her out. You wouldn’t by chance have one floating around ? I just wanted to know what all the components are and where the bearing are located.
Regards
Luigi Anselmi
Rivedel II
