I am curious of the wiring routing/setup for the deck mounted solar panel on the Hunter 460 (and other similar sizes as well). Photo of the panel below. Does it come in and attached to a MPPT/regulator somewhere and then to the battery charger? If so where. the manual mentions nothing of the wiring.
I also have four solar panels that were installed after market on the davits and Bimini top. I'm still trying to track that wiring down and how it works as there is definitely no MPPT for that. previous owner had the wiring disconnected at the solar panels because "things would get too hot" (like the battery).
I recently purchased the boat in June so am still working through systems and other priorities. Wanted to get all the info I could before I start tracking things down. Thanks in advance. Stay safe!
