I'm a new sailboat owner and I am in the process of performing a bottom job on my 1984 Hunter 25.5 that i picked up a few months ago. She sat in the ocean for several years and had quite a bit of growth on the bottom when she was hauled. Since I don't know the type of bottom paint used, I am sanding all the old bottom paint off and starting new by adding a few layers of barrier paint before I bottom paint. As for the keel question, the keel is very rusty and I am using a wire brush on an angle grinder to clean up before I seal it with POR-15. The back of the keel looks like there is either a piece missing or it needs to be faired to make it smooth. I guess my question is, if the I don't have any leaking at the keel joint, do I need to dig out the old sealer or just wire brush it very clean and fill the voids? I have included a couple pictures to see what you guys think. I will be sailing in freshwater lakes here in Oklahoma and will probably leave it in the water year around. I plan on hauling at least once a year to clean the bottom and check everything out. This Newbie thanks any and all comments.
