Hunter Fiberglass Arch
3
- - Port Clinton, OH
I just purchased a 1999 Hunter 310. The Arch leaks and is holding water. It is also cracked and I would like to replace with one of the SS Arches found on the later models. Can I replace this SS Arch for the Fiberglass Arch? If so, does anyone know where I can find one of these Arches? Thanks for your help!
W
wafle
I would
just drils holes it! Not worth spending the money on. It is not the only problem your going to have!
Rick D
Jun 14, 2008
7,203
Hunter Makes Their Own
They used to outsource them, but now do it in-house. There may have been changes in the reinforcing areas of the deck between the two, so it is worth a call to them. I suspect there may be one or more available used what with all the totalled boats these last seasons, but I would not know how to go about hunting one down. You are probably better off having it removed and then re-bed it. As to the holding water part, I'd be inclined to drill a drainage hole too. Rick D.
