Hunter Demasting
H
Howie Kay
Hi, Do you have a source for a replacement hatch cover for the front hatch of our 1977 27 foot hunter sailboat? Can the original hatch material be repaired with epoxy resin? I have a small crack in the area of the deck hinge. On July 15, during a 25 knot wind on Barnegat bay, the shroud U bolts broke at deck level on a 25 foot 1977-1979 hunter sailboat. I do not know the exact year of manufacture. But it has a tiller, outboard motor, and the windows are similar to my 27 foot 1977 hunter. I do not know what the tension was on the standing rigging without sail load. However the turnbuckle hardware, which was constructed of light gauge material, was not bent and did not seem damaged. The owner's insurance company stated that the u bolts should be replaced every seven years as a regular maintenance procedure. I have never heard of this happening in the twenty three years I have owned my 1977 Hunter 27. We sail in Barnegat bay on the Jersey coast. The Bay usually has 10 to 20 knot winds during the summer. Our Hunter is insured by Boat US. I e-mailed the Boat US Seaworthy Division. They searched their insurance claims database for similar damage claims. They did not locate any demasting incidents related to deck hardware failure for the hunter sailboats. What has been your experience with the U bolt fastening system on the Hunter Sail boats? Thanks, Howie
G
Gene
Source
Look under sailnet.com They carry lots of things for Hunters
G
Guest
Also check...
Boat/US special Orders Desk. You could get it cheaper.
N
Neil Smith
Hatch
I think that Bomar used to offer replacement hatches, but as far as I am aware they don't anymore. The hatch on my 1978 H-27 was refabricated by the PO and serves it's purpose, however I am plagued by catching the sheets on the lip of the hatch. If you re-fabricate yourself, I'd recommend against any type of lip that can foul your sheets. As far as replacing the bolts, it's the first I've heard of it. Remember though, your (and my) vessel are approaching the quarter century mark . . . Neil Smith
Jack Laird
Epoxy
Can repair hatches with epoxy, I've done it and it worked fine. Bomar has replacement for center hatch but I have not been able to find a replacement for the fore hatch.
N
Nelsonhow
Out of Luck on a Replacement- Bomar square
I had a similar problem with my 78 Hunter 27. The trapizodial hatch is no longer made and there is no standard trapizoidal that has the same dimensions. I spend 3 months over the winter looking. I replace the old hatch with a standard Bormar square hatch and had to cut out the front of the hatch opening a little bit. If you'd like to know the size hatch I used as well as the technique email me at nelsonhow@aol.com and I can fill you in. It took about 6 hours to refit the new hatch. NO LEAKS NOW.....
