Hunter 456 hanging bag
boodog
Dec 21, 2007
1
- - Kemah, TX
Could someone please tell me where I can buy a replacement canvas hanging bag for a Hunter 456??? This is the 4 zippered compartment bag that hangs on the aft head door around a teak semi-circle block on the top and bottom. Other Hunter models may have this bag as well. I believe it was meant to be used for head items since some of the compartments are lined with plastic.
P
Pete
try Hunter factory
direct to the parts department or if you check your owners manual, it should tell you who the vendors was and maybe you can purchase it thru them direct. Either way Hunter factory should be able to help you out.
