Hunter 42 fridge seal material
eianm
Jul 7, 2010
523
Hunter 42 Sydney
I have spent 2 years trying to seal my fridge and freezer lids- tried multiple different types of seal- NOTHING has been successful. Hunter don't list anything on our forum shop- does anyone know a source for the original style seal material?
Jan 12, 2011
930
Hunter 410 full time cruiser
I added a layer of standard 1/4" one side sticky weather seal to the seal in the boxes of my 410 and it made a big difference and has worked for 3 years now. I also finally got tired of battling with the plastic latches and just took them off and found the the lids seal better now just using their weight.
Jun 2, 2004
121
Hunter 430 Shelter bay, Panama
I used closed cell foam tape. there are different thicknesses and densities. I find it works well on the freezer and on the lazerettes to keep dust out.
Jun 13, 2004
90
Hunter 40.5 Hampton,Virginia
I found the original dealer for the freezer and refrigerator gaskets used by Hunter for my 40.5. Dealer is Refrigeration Hardware Supply Corp. RHS - Refrigeration Hardware Supply Corporation 800-423-2446.
eianm
Jul 7, 2010
523
Hunter 42 Sydney
thanks all- the amazingly knowledgeable and helpful Eddie Breeden emailed me the RHS contact details- thank you Eddie!
May 10, 2010
15
Hunter 31 and 42 Cape Coral, Tarpon Point
My Hunter 42 has new coolant motors/pumps and draw roughly 5-8 amps and were running almost constantly. I placed a rubber plug in the drains and now the systems draw less the 3 amps and run for a few minutes per hour. Freezer at warmest setting is 6 degrees and needs to be defrosted one time per month. Refer stays at 36 degrees at warmest setting.
May 24, 2012
64
Hunter 42 Florida
I am also needing to replace the original seals for my fridge and freezer. If these work please let me know so I can order them.
Thanks,
Tom
