Successfully completed replacing all the sanitation hoses on our Hunter 41 DS with Trident 102 (white) hose... can already smell the difference!!!
The 'aft head (AH) to holding tank (HT)' hose has a low portion that is lower than the HT access, as Hunter built it (no way around this), so there will always be liquid in that 'low' area... gravity will not drain that portion. Thus replaced the 1.5" hose with 1.0" hose (to match the head output) with 6" of 1.5" hose to adapt to the HT inlet. This will require less water to clear the hose of 'head debris' to the tank, whereas the original 1.5" hose required 30% more water to do the same... so far, so good
All other hoses were replaced with the original sizes. Did not modify the 'fwd head (FH)' hose to 1.0" as this head is rarely used, the extra amount of flushing to clear will not be detrimental to the fresh water capacity & already had 1.5" hose on-hand (in the future when required will replace this hose with 1.0" to match the aft head configuration).
The vent hose according to the Hunter Owners Manual is supposedly 3/4"... but 5/8" was found to be installed.
FYI: for those who asked, the hose lengths are as follows...
- aft head to holding tank: 141" total (orig 105" of 1.5" + 36" of 1.0")
changed to (135" of 1.0" + 6" of 1.5")
- fwd head to holding tank: 146" total (198" of 1.5" + 48" of 1.0")
- holding tank to macerator: 55" total (1.5")
- macerator to thru-hull: 28" total (1.0")
- holding tank to pump-out: 120" total (1.5")
- holding tank to vent: 120" total (5/8")
Thanks everyone for your assistance (especially Peggie)... I will update on any performance issues.
jb.
