Hunter 41 anchor chain size
Jun 11, 2011
1,243
Hunter 41 Lewes
I mic'd the current anchor chain and it seems to 9mm. It is a Lewmar windlass and I was wondering if this was the norm for the 2006 version of this boat.
Dec 25, 2000
5,912
Our Maxwell windlass takes 5/16" G40. What exact part of the chain link did you measure to arrive at 9mm? It should be the narrowest space inside the link. To make sure what I did was to take one link to a local industrial supply company where they sold me the matching size in the length I wanted. Worked perfectly. They even let me borrow their link cutter at no charge.
Jun 11, 2011
1,243
Hunter 41 Lewes
I used a micrometer and measured it in several spots. It is not very consistent in measurement. That is why I asked the question. It seemed to average 9mm but by being marked 3B it should have an imperial measurement.
Jun 15, 2012
715
BAVARIA C57 Greenport, NY
My 41DS came from the factory with 5/16 chain. The ACCO chain website shows a "wire" diameter of .329" which may be before galvanizing. Also I'm sure there is a tolerance in the wire diameter which may all be on the plus side.
